Pook demonteren
Pook demonteren
Even een korte vraag ik kan het namelijk nergens vinden, hoe demonteer je een automaat pook?
-330d 184pk e46 Touring AUT. pré facelift 2000.
-330d 184pk e46 Touring AUT. facelift 2002.
-330Cd 204pk e46 Coupe H6 facelift 2004.
:duimen:
:duimen:
Re: Pook demonteren
Gewoon met 2 handen vast en naar boven trekken....
- Spoiler: Laat zien
Re: Pook demonteren
Elders gevonden:
Uiteindelijk een kwestie van hard trekken dus....Hi everyone, I have tried to remove myself of the "Steptronic Auto Shift Knob Yesterday" It's work. Just following the step below!
Step1: Use a flat screw to pull the middle counsole clip up gentally. After it' up, you can see it's stick with the shiftboot together! Don't do anything for it, after it's up, it will be more easier to take out the shift knob!
Step2: Use your car key to turn to the second stage, not to drive ur car, just the second stage which you can see the cluster light is on, then pull your shift knob to "N or R" it's up to you, but remember..make sure your handbrake is pull up before you do that!
Step3: As many people saids just pull up as hard as you can.....they're right! this will totally work, but you need to sit in a right position to do that so!
Sit at the center and two legs on the seat, open the roof window!
Step4: Try use both hand to turn a littlebit "left & right" for the shift knob before pull it up, this will help it more easiely to pull up. After you do this step, just pull it up, and it will pop out!
This is a very easy step to do so, Hope it's help, I do this my own and it works!
Re: Pook demonteren
Het is mij ook gelukt zonder open dak!!Rene08 schreef:Elders gevonden:Sit at the center and two legs on the seat, open the roof window!
Re: Pook demonteren
Gaat er natuurlijk meer om dat je hem niet in Park zet, omdat je dan moeilijk kracht kan zetten.
Re: Pook demonteren
net alles vervangen, NO PROBLEMO!
:duimen:
:duimen:
