Digitale airco maken van handmatige..
Re: Digitale airco maken van handmatige..
Wie gaat binnenkort een setje kabels bestellen en kan een setje mee bestellen voor mij.
ik betaal uiteraard voorruit en verz.kosten.
Ben niet zo weg van de BMW dealer in Heerenveen.
- fastfisico
Ik weet niet of er kant en klare kabelbomen zijn voor de ombouw.
Zoals ik al eerder heb omschreven kan je de bestaande stekkers ombouwen.
Hieronder in het Engels de bestelnummer van de stekkers en de omnummering van de pinnen.
Succes!
Groet Ingvar
Parts needed :-
AC control panel high (IHKA)
Socket housing black, 2 pol 61131378108 x1
Snap in receptacle 61131376204 x2
Universal socket housing uncoded, 26 pol 61136913626 x1
Covering cap blue 61136913644 x1
Solar sensor 64116944017 x1
Bushing contact 64116944017 x4
Before you start you need determine where the basic panel gets its power.
According to the WDS for cars upto sept/2005 the power is at fuse 26 front fuse box
For cars after sep/2005 the fuse is at fuse 57 rear fuse box, the basic has a 7.5 amp fuse and the high has a 15 amp fuse.
Disconnect the battery before starting.
Dismantle the dashboard :-
Remove the dashboard I-strip, undo the two screws securing the IHKA cover panel, use some slight force to pull panel out of its clips.
Disconnect the two black plugs from the AC panel and put panel to one side.
New pin assignments :-
The basic AC has two plugs :- X01130 12 pins and X18793 18 pins.
The High AC has three plugs :- X01130 12 pins, X13765 2 pins and X1527 26 pins
Carefully prise out the plug from the cover cap of X01130 (12 pins, left hand plug) and swap pin 1 to pin 2..
Carefully prise out the plug from the cover cap of X18793 (18 pins, right hand plug).
Follow this next list to assign the pins to the 26 pin socket contact :-
X18793 X1527
1-----------------1
2 not used
3 ----------------9
4 ----------------8
5 not used
6 ----------------6
7 ----------------7
8 ----------------21
9 not used
10 see explanation for X13765
11 --------------15
12 --------------17
13 --------------18
14 --------------14
15 --------------20
16 --------------14
17 not used
18 See explanation for X13765
For the solar sensor connect :-
Sensor X1527
1--------------- 10
3 ---------------11
4 ---------------12
2 ---------------13
After this is all done, you should have two pins left, these are power and ground (1 red, 1 brown).
Cut off the pins and add around 6 inch of red and brown cable to each, fit the snap in receptacles to the new cables and snap in the red to pin 1 of the 2 pin connector and the brown to pin 2.
Now for the fun part, connect the new connectors to the new high panel and put a 15 amp fuse in to replace the basic 7.5 amp fuse and re-connect the battery.
Switch the car on and the panel should light up, now the car will need coding for SA534 automatic air-conditioning.
Succes!
Groet Ingvar
Parts needed :-
X18793 X1527
1-----------------1
2 not used
3 ----------------9
4 ----------------8
5 not used
6 ----------------6
7 ----------------7
9 not used
11 --------------15
12 --------------17
13 --------------18
14 --------------14
15 --------------20
16 --------------14
17 not used
Sensor X1527
1--------------- 10
3 ---------------11
4 ---------------12
2 ---------------13
Downsizing..... waar gaat dat heen met BMW.......
Done!Broncky schreef:Heeft iemand m nu al vervangen???
Wel een hoop priegelwerk om de kabels uit de oude connector te krijgen.
Wel heel mooi geworden.
Na programmeren heb ik dus nieuwe opties in mijn idrive (bij Klimaat) erbij gekregen.
Was te donker om mooie foto's te nemen.
Laatst gewijzigd door Ralph op 19 jan 2012, 23:45, 1 keer totaal gewijzigd.
Kijk! En hoe programeer je de boel? Met ncs?
Moet iemand toevallig nog deze kabels bestellen? Zoja kun je deze voor mij mee bestellen ik maak het wel over.
Grt
Grt
Pluto,
Is het nou inmiddels gelukt?
Ik ben bezig met een kabel die een soort plug and play wordt (qua ompinnen dan).
Want het ompinnen is een helse karwei zeg,
edit...
Wellicht gaat dit niet door.
Het wordt best prijzig wordt want ik moet 2 * 16 kabels hebben (kosten 1.25 per stuk bij de dealer).
En dan nog de connectors. Dan zit ik op 60 euro denk ik voor de onderdelen.
Voor dat geld kan je denk ik beter een uur gaan priegelen in de auto.
edit...
ja inderdaad. Nou ik moet nog dat setje bestellen.
- fastfisico
Gewoon bij de dealer bestellen.
Ik heb het via email gedaan, duurde 2 dagen en toen kwestie van oppikken en betalen
Ik heb nu een ombouwkabel inelkaar geflatst conform de ombouwlijst van de connectors X18793 --> X1527 zoals een paar posts hierboven is afgebeeld.
Met deze kabel scheelt het een flinke tijd in een krampachtig houding de veel te korte kabel met de 18 pins connector X18793 lospinnen en ompinnen naar de X1527 (26 pins) + X13765 (2 pins). De 2 laatste zijn op- de foto te zien als de grote blauwe en de kleine zwarte.
Dus nu kwestie van handmatige ac panel eruit.
Ombouwkabel klikken in de oude kabel.
Connectors klikken in AC high paneel.
Klaar
Klaar
- Spoiler: Laat zien
Laatst gewijzigd door Ralph op 29 jan 2012, 19:05, 1 keer totaal gewijzigd.
- fastfisico
Kijk daar zal Pluto blij mee zijn
Zo dat is een stukje vakmanschap...! Heb je die connector besteld en daaraan de oude bevestigd? Als
dat zo kan zoals jij beschrijft lijkt mij dit ook een dikke optie!
Yep.. alle onderdelelen besteld bij de dealer (muv de laatste):LuukE60 schreef:Zo dat is een stukje vakmanschap...! Heb je die connector besteld en daaraan de oude bevestigd? Als
2 *14 bushing contacts
blauwe afdekkap
2* receptable
Stopcont. huis (2 polig)
26 polig bus
aansluitbus (Deze zorgt voor een mooie verbinding tusen de bestaande kabel en de nieuwe)
Totale kosten van de onderdelen 52€
Als ik de bushing contacten elders kan vinden kan dit de prijs flink droppen.
Het is hiermee echt een kwestie van minuten om de paneel om te wisselen.
Dit betekend dus dat ik voor zo'n €150 digitale airco in die van mij kan krijgen
Zag namelijk op ebay zo'n airco paneel
voor €80 en dan die andere onderdelen nog.
Heb je toevallig nog een rekening liggen waar de onderdeelnummers op staan? Dan ga ik het namelijk ook proberen ( trainen om iets
met één hand te doen )
Bedankt Ralph..! Maakt het trouwens uit welk airco paneel ik bestel of zit er weinig verschil in?
Een vraag aan jou off topic: Aangezien jij zo handig bent
weet jij dan ook of ik makkelijk business navi in mijn auto kan bouwen? Ik
heb namelijk pas geleden zo'n set gekocht voor een geschikte prijs. Je mag mij dit antwoordt ook wel pm'n, blijft het hier toch nog
Je moet in ieder geval een Pre-LCI airco paneel hebben meen ik.
